Hi
The board / BIOS would appear to select 1333MHz with 9/10/10/25 timings as default.
Now I know that you can select XMP in the BIOS and run the memory at it's rated value. (IE.1600MHz 9/9/9/24).
But quite happy to leave it as is, if only because it runs at 1.5v at 1333MHz, rather than 1.65v at 1600MHz.
A couple of questions though.
1) Am I "really" loosing much by running the RAM at a slightly lower speed?
2) Are the timings OK that the board sets?
It's just that the SPD values CPU-Z shows are 9/9/9/24 for 1333MHz!
Thanks in advance.
PS. IBT and a couple of hours of Prime95 appear fine. And the BIOS memory test passes OK. I'm just being a bit cautious.
Thanks in advance.
