Hi Guys
If I set my CPU fan to Q-Fan controlled in the bios screen then it boots with a 'CPU Fan Error'. The fan is running at 530RPM which is below the allowed threshold. I've tried all the modes, silent, normal and turbo.
The fan is an Akasa Apache Super Silent 120mm 4-pin PWM fan. I bought it specifically as it's a PWM fan. The motherboard is an Asus P6T SE.
Has anyone else had the same problem? Thanks for any advice.
By the way what did they paint that fan with? It stinks!
