I'm using that guide at the moment, on my P6TD Deluxe and 920, so far I've used the "s*rew efficency I want 4gig" section and seems to be working ok.
One thing that doesn't seem right however, are the temps, they seem to low compared to others. I'm using real temp, calibrated it and set the tmax to 90. Bearing in mind i'm on an open bench, the large fft prime hasn't gone over 60 (i'm using a mega shadow and a medium speed yate loon, vcore 1.12, 21x190).
Do you think i've messed up the calibration?
This calibration is making your temps appear lower.
Is there a guide on how to overclock a i7 860?
Because I do not have a clue in the slightest on how to overclock.
Are you still using the ***** efficiency option Arcane?
Good luck mate, bit different from my own approach, but if its stable and you can lower voltages thats always good.I started by using those settings, once I tested that was prime stable I started lowering the voltages and then re-testing, basically doing the first method in the guide in reverse.
