Paddock stand ZX6R
12 Mar 2006
N.E England
Hi all
I have a 97 ZX6R what stand in particular / bits will allow me to elevate the bike to start to get to know the bike better / oil chain etc.
Complete newbie
I'm not sure if it's too old to have as an option but if you look on the swingarm, next to where the chain nut is, do you see a small threaded hole on either side?
Abba stand is the way to go if you want to start doing your own work on it past adjusting and oiling the chain.
Abba stand for lubing the chain is a waste of money, a normal stand of ebay with the flat bits is more than enough for that. lol
e.g. http://www.ebay.co.uk/itm/Warrior-R...dock-Stand-Track-Day-Garage-Pit-/371169071935
If all you're going to do is lube the chain and remove a wheel then yes it's not necessary (don't buy the version you've linked to though, wobbly rubbish, pick up one of the aluminium box section versions they're solid)
The abba stands allow you to remove wheel, shock and with a pair of £20 adaptors the swingarm too. The front lift arm will allow you to remove front wheel, forks, yokes too. You can strip the bike down to just it's frame using an abba stand.
invest the extra in an abba . it will last you a lifetime of bikes and is a lot more flexible than normal paddock stands
True, for heavier bikes it ain't great, my bent under SV's weight once when I was putting it on uneven ground. It was scary and dodgy...
Just get an Abba, if it'll be time that you want to sell it. I'll buy it of you... :p
Okay so I need the abba and what fixings? I can jack a car up but bikes I'm lost LOL
I want to get to know the bike and eventually start servicing it myself
The fixings are all selectable from the abba site, based on make, model and year of your bike.
http://abbastands.co.uk/product-detail.asp?item=superbike-stand&pid=1
Choose these from the menu and you are sorted. :) Also add another £55 on top if you want the front lift arm add on.
I've always thought they were quite overpriced for what you get. Just compare the (lack of) complexity of the construction to a set of paddock stands.
Yup, they're pretty much made out of bits that I would have made in my resistant materials classes back in the day :D
Abba stands area faff compared to a traditional paddock stand or compared to a strongarm but what they lack in convenience they make up for the fact they are a universal stand and lift the front as well as the back.
Depends on the paddock stand I have come across some crap in my time the abba stand may be a little over priced but build quality is adequate and consistent.
Yeah generally I'm comparing it to quality paddock stands. As you say, the £40 ebay specials can be terrible :P
