You need a machine (£70?) megs 105/205 (£25) a few pads (£30) and maybe tape, mf cloths etc (£20)
you can do a whole car in an afternoon and you'll have the stuff then for future use. No brainer IMO![]()
Disagree with you almost entirely. If you are going to machine polish then you need to clay too. Though clay only goes so far so if the car hasn't seen much attention then probably would best to add tar and fallout removers to that list also. Also if you are going to machine polish then definitely need to add some LSP.
As for the time, if you can fully machine polish an entire car in an afternoon you should set up a business as you could detail 2 or 3 times as many cars per day as the pro's do. Even a single stage polish takes around 2 or 3 hours alone, nevermind all the prep time before that in washing, decontaminating / claying and then the time after applying a couple coats of wax or sealent. If aiming for a single stage polish though, IMO a diminishing polish would be better as unlike the Megs so you can relatively easily finish down hologram free even with the high cut polishes.
If sticking to only paintwork then you could do it a day. Obviously if going for clean and seal wheels, glass, trim protectants etc it becomes a struggle to do in 1 day.
