After having the bigger fittings for the catch can welded on, it required painting (the red was flaking off anyway) so ive had it powder coated he same blue as the gworks logo.
The car is gonna be white black and blue, so far the only bits that are blue are the logo on the seat and this, but more to come - tastfully of course
Currently fitting an oil cooler and filter relocation kit - lots of nice looking and expensive earls/aeroquip/mocal fittings!! Also fitting an oil thermostat so there are no issues with oil temp/viscosity when cold.
Also bought an AEM UEGO afr gauge, im getting the bung welded into my decat this week and then fitting that also. AEM EMS is next on the list
The engine bay needs a good clean, this is only test fitted to take some pics. Im thinking of masking off the lettering on the plug cover and painting the letters white the same as the car.
look dirty on the right top bolt though?
