- 23 May 2006
So after having my living room re-plastered I have started giving the walls a mist coat with Leyland contract matt emulsion. I used 10l paint to 1l water
I have come across two problems which I hope someone can help me with.
I have come across patches where the paint will not soak in as much, if i try painting over the patch again with a brush or roller it just drags it
The other problem is around the window reveals where the corners have angle beads, I give the angle beads a coat of zinsser 123 water based paint before the mist coat, this is to prevent any rust stains ruining the wall. However in between the mist coat where the two paints meet up you can see it looks rough.
I did try and sand it down with 120 grade sand paper between mist coats but it's not done much after applying the 2nd coat
I've included picture
[/quote]
