Painting TV bezel
7 Aug 2017
Oxford
Just bought a Samsung TV at a local clearance sale and although the TV is perfect the silver bezel does not match the other furniture. Has anybody painted their TV bezel? Wouldn't mind a non permanent solution which can be removed easily in the future.
I did a PC monitor back in the day with plastic paint. Plasticoat is probably your best bet nowadays for something easily removable.
Are you planning to remove it entirely then paint, which is what I would suggest, As I personally wouldn’t just do it by masking..
Get a good plastic undercoat first as paint on plastic always rubs off sharp edges if not. And maybe a nice top coat to protect it. Plastikote is a good brand, apply thin and build it up.
I would rather mask/cover it with the pvc trim as it's much easier to remove if needed. I would certainly not remove the bezel to paint it.
