So, another day, another bit of modding!
I took apart the CPU block and the rez, and chucked them into my spray box of awesomeness.
Gave them a good coat of primer and white paint.
Once this had dried I started to add some purple!
hmmmm, white and purple!!
The rez, im not 100% happy with the paint job on this, but for now, it will have to do whilst i sort out the loop. If i get time, I will be redoing it!
Both together
I got the dremel out and cut the slot so that the motherboard tray could sit flush!
GPU placement hopefully!
and where it will roughly sit, don't worry, the mounting will look far better when i do it properly lol.
Confused (Garry) from the OcUK forums was helping me today, he bought his pillar drill around, as i don't have a workshop or garage, we were kitching modding as per usual. LOTS of dust and metal flying around today!
Although it looks like we have done very little, we really have made a lot of progress today. Garry has gone away with a little task... re soldering a PCI-E riser... 164 pins and counting!!! This is so we can give the card the angle I want. If we cant, then I will have to change the angle slightly so that we can ensure that the riser doesn't get blocked by the PSU.
It's starting to come together now!!
