Panel filter...which one?
green air filter. More quality than K&N and cheaper :) :) After all they are all basically the same, so get the cheapest. I just purchased a green for my gti6 and fitted it yesterday, very impressed. Oh if you want noise, dont buy one unless you want to drill some holes, cones are for noise.
