Panel mount PSU sockets
13 Sep 2009
Maidstone, Kent
I'm doing a revamp of my modded TJ07 and wanted to address one of the largest issues I have with it- cable management. In addition, my favourite feature is the removable motherboard tray, however you can only do the wiring once the tray is in.
So, I came up with a slightly ridiculous plan! I plan to mount sockets for 24-pin ATX, PCIE and 8-pin CPU onto the motherboard tray itself. Essentially, I'm hoping for a socket with two female connectors with one side able to mount to a panel, like a thru-connector. This would allow me to run a braided extension from the socket to my components which I could do while the motherboard tray was out. Then, I'd slide the tray in and connect my PSU to the socket on the other side of the tray.
I've searched and I can't find anything, does anything like this exist?
If I were to do that, I'd just make the 24/8 pin just long enough to mount in a cut out , then plug the cable in from behind the motherboard tray from the psu as normal.
