Panning Time-Lapse devices for DSLR's? Are there any DSLR versions of Egg-Cup timer style devices?
12 Jul 2007
Stoke/Norfolk
Hi all, I've got a £5 Ikea egg-timer with which I did some panning time-lapse test shots of a rally service stage being setup using with one of my in-car Drift HD cameras and while the idea worked brilliantly I couldn't use the shots in the video as the still images provided by the DriftHD were pretty poor quality as the Drift isn't really designed for photography.
Is there anything reasonably cheap out there that is a "bulked up" version of the ikea egg timer that would take the weight of DSLR's?
I've seen this kickstarter project and it looks like exactly what I'm after only it's $150 and it's full of over the top tech that I really don't need like iphone/android control & the device controls the shooting through the cameras PC port etc etc. If they did a cheaper version which just did the spinning bit and nothing else it'd be ideal!
the timed shot bit is easy, 10quid remote from egay will get u that bit, i had a quick look at rotating tables on there too but couldnt find anything controlable
I made one that would rotate a set number of degrees (selectable via a switch) and trigger the camera via the remote release after each rotation. However it cost ~£100 in parts to build so if you think $150 for a finished product is too much then it's not for you.
Cheers for the replies so far! I haven't been able to find anything on POTN either which really surprised me, although there's some great Heath-Robinson engineering going on to make home built versions :D
Cheers, I've already got a wireless timed shutter release (£20 from the Bay) so it's just some kind of rotating platform I'm interested in.
Thats virtually what I've got now although mines very "hobo made" after I've glued a nut to bottom and bolt to the top of my egg-timer to get the same effect.
