Paragon drive alignment tool v3
16 Sep 2009
Loogabarooga
Is available for download from Dell via it's support.
Goto drivers and downloads, select laptops and latitude and the e5420 model (others may work) and select XP as the O/S.
Now goto SATA and there should be the download link for PAT which includes the product and serial number key on extraction.
It may be limited to use on Dell PC's but I could not see and customization on any of the menu's or anything.
Interesting! I found that their software is the easiest to use for aligning partitions. Works for both SSDs and advanced format HDDs.
