Part-Upgrade Advice Required :)
17 Oct 2010
S.Wales, UK
Hey guys I have been registered to this forum for ages but haven't really posted much. I built a PC 2 years and a month ago thanks to your advice and I'm now looking to upgrade...btw sorry for another one of these posts I know there are quite a few already but you guys seem to know what your talking about so I want the best advice and I know I'm going to get it =].
Basically I want to upgrade a few of the main parts in the PC which are the Motherboard, CPU and RAM and possibly change my WD Caviar Black 1TB HDD with a SSD Drive.
My current Motherboard is a Gigabyte MA790FXT-UD5P
CPU is an AMD Phenom II X2 560 Black Edition 3.3GHZ
RAM is just your basic 4GB of ram running at 1066mhz (used to dual boot with XP so had to stick with 4GB)
I want to keep my Sapphire 5870 Graphics card (upgrading to the 7970 when I can save up for it), HAF 932 case and Corsair HX 850w PSU, SB X-fi Fatality Series sound card along with the Blu-Ray and DVD-RW drives I have.
I use the system for gaming mostly along with the odd Office applications and I'm currently in the process of ripping my entire DVD collection to ISO images and encoding them to mp4's for use on my home NAS..so that's what the system's primary functions are :).
I'm looking to spend around £800 on the Motherboard, CPU and RAM since I'll be upgrading the graphics card in a further month's time that's not important at the moment. Also looking for a bit of future proofing so USB 3.0 and PCI 3.0 would be great too!
Also i'm considering a water cooling system for the CPU so I would probably be better off going for a stand-alone unit like a Corsair Hydro series cooler? I am open to a complete water cooling solution for the entire pc though as I would love to have a "silent" pc :).
Cheers all I look forward to your advice!
Thanks for the reply Lemin, is there any benefit to going for the Asus P8Z68-V-GEN3 over the Pro or Deluxe editions or a board like the Maximus IV Extreme?
Also I don't understand the difference between the chipsets, is there any advantage to going Z68 over P67/H61/H67? Also what's the difference between the Intel 1115 and Intel 2011 or Intel 1366?
How good is the i7 2700k for overclocking too?
I've been out of the building loop for a while.. lol
Thanks again!
That was the exact SSD I was looking at before I read your reply :). I will definitely go with the i7 2700k sounds like I have myself a good upgrade to get to.
One more question about the RAM..it's stated to run at 1600mhz but I should be able to overclock that to 1866/2133 shouldn't I with that processor?
Ok cheers for the advice on the RAM Lemin will stick with it as it is :)
Yeah I think that would fit in my case beejjacobs, I should hope so since the HAF 932 is the biggest case I own :P
