Firstly, apologies if this is in the wrong section. As its audio related, i opted with this section.
I have a Gigabyte G1 Sniper M3, which uses Recon3di. All was working fine before powering down to swap the GFX cards in the system.
I upgraded my GFX card, and following on from this, the ports for the centre/sub and rear speakers appear to have stopped working.
I have checked the speakers, and they are all outputting correctly. I first tried disabling the sound card, rebooted, re-enabled, still the same. I then uninstalled the drivers and rebooted. Drivers went straight back on when the PC rebooted, and the problem is still there.
I have disabled all other audio devices in the PC, related to the audio output from the GFX card, and this has also made no difference.
I don't remember hitting or damaging the mobo when I installed the new card, but at this stage, its all I can think of that could have caused a partial failure of the ports.
If anyone has any bright ideas, I am all ears.
Thanks in advance.
Thanks in advance.
