First time watercooler looking for some advice for a CPU only loop for a 3930k in a Haf X.
EK Supremacy - Copper Acetal - £51.98
Hardware Labs Black ICE Radiator GT Stealth 360 - £49.99
EK DCP 4.0 Pump 12V - £39.98
EK Multi-option Reservoir X2 150 Basic - £28.98
Masterkleer Hose Pack PVC 16/10mm (3/8ID) UV-Reactive Dark Red 3.3m - £10.88
EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel x8 - £22.00
= £203.81 plus shipping
Is all the stuff compatible? It should all be using G1/4, but I may have missed something.
What savings could I reasonably make?
Aside from pump vibration damping, fans (which I already have) and distilled water (buying local) is there anything else I should get?
Should I go for a biocide or a kill coil?
Thank you.
Thank you.
