Parts
8 Oct 2007
Hello,
I'm trying to build a pc for a friend, I have a budget of £100 for the following,
Mobo needs on board graphics, CPU and memory. If we can get a separate gpu we could probably go to £120max.
Thinks its do able?
Thanks,
The Badger.
Well yep, the 1600 has similar timings so there will be an improvement - although these days memory doesn't affect things much.
OP - Is the information we've given helpful?
Of course, your spec halk, does it have graphics? From looking at them I cannot seem to find if it does, or should I just add the 5450?
The mobo is out of stock ;(
