I'm testing a Zotac 1060 Mini
Lovely little card, runs 1911Mhz out of the box cold, soon drops to about 1860 once at its running temp of about 75c.
Its only got a dinky little single fan cooler on it so i'm not expecting a lot from it, its also perhaps not the best Pascal card to test.
I turned the Memory up to 4200Mhz (+200), it only made a marginal difference so i left it at that.
I don't want to push the core too high as its already pretty high out of the box, i hear they run about 2050 to 2100 reliably.
I'm testing it in 50Mhz increments, i have only taken it to +100Mhz as; and this is the question- thats not what i got out of the card, from 1911 with +100Mhz what it actually started out at was 2000Mhz dead on, so actually +89Mhz, close enough, however as soon as it warmed up it fell back to 1940, so in the end actually only +80Mhz.
I have a feeling that the card is thermally constrained, its actually going to be quite difficult to get it to run at 2050Mhz or 2100Mhz, normally with less beefy cooling you should still get good clocks all be it with higher temps, maybe just over 80c instead of just over 70c.
But it seems this one doesn't want to go there, not that i have pushed it more and the reason for that is if 350Mhz actually translates into 200Mhz i don't trust it not to spike or something like that.
Comments please
Comments please
