Passat projector lens LED retrofit
Probably because they output less than 2000 lumens and so are below the legal limit for requiring washers.
2500 lumen then 4000 lumen high beam. No washers or wipers.
They cause problems with coati-driving headlight adaptors - mine peeled off as the put out quite a bit of heat out the front of the light.
Ran into a blocker fitting the LED to the VW Passat.
The push and twist lock mechanism is built-in to the power cable. I will most likely need an adapter to hold and lock the new LED in place.
Anyone know if such adapter exist and where to find it?
