Why passive? There are extremely quiet actively cooled PSUs that cost a heck of a lot less. Check out the Corsair HX 520 for starters. Mine is inaudible.
VX 450 != HX 520
The 450 is a budget PSU.
I have ordered the vx450. It will go in my bedroom PC, which needs to be quiet. It will be used almost like a HTPC.
I will let you guys know how it goes, as I will be using it to overclock a C2D to 3Ghz+.
From all the reviews Ive read (and Ive read many), the vx450 is a very good power supply unit. vx520w is overkill unless you intend to run SLI.
Have a read:
http://enthusiast.hardocp.com/article.html?art=MTM3NSw5LCxoZW50aHVzaWFzdA==
