- 22 Feb 2010
having just replaced the stock cooler on my htpc, now all i can hear is the darned power supply im wondering whats the cheapest and safest way to power it passively
i see it as i have a couple of options
1, buy a fanless 400w psu @ £70+
2, pico psu and deal with the brick and massive hole in the case [£100<]
3, hack apart my trusty old corsair cx 430w i have had for a long time and disconnect the fan.*free
4, replace corsair fan with noctua?
the only reason i suggest point 3 is because the fan spins 24/7 and the air is ALWAYS cold, i have put a thermometer behind it and it only reads 1-3c above ambient.
my power needs are very low
25w 5350
3w max intel network dual nic
8w max pcie tv tuner
xonar dx 7.1 sound card [unknown wattage]
1x SSD
usb: 1x remote reciever, occasional wired 360 controller [when using steam streaming]
average 'idle' draw is about 22-28w total [idle being watching / recording tv, what it does 99% of the time]
load i have never got it to go over 38w running benchmarks
startup wattage peak is 42w
25w 5350
1x SSD
