I'm looking to move my system over from my Lian Li q07 to a Streacom FC8 fanless case (http://www.streacom.com/products/fc8-fanless-chassis/) and am having difficulty deciding what to do in terms of processors.
Currently I have a 2500k in my system, it is probably overkill as I only use my pc for browsing and music/movies. I don't play games any more so the processor is rarely stressed. Now the case in question states that it can handle a cpu with a max TDP of 65w. The 2500k is a 95w TDP processor, however if I will never be stressing it too much then surely this should not be a problem as it will use only marginally more power and produce marginally more heat than lower power processors. For this reason I think it should work fine but would like to verify this. The way I see it I have two options:
1) Keep the 2500k - saves hassle of selling and buying replacement, may overheat (or will it)
2) Sell the 2500k and buy a lower power i5 or i3
This leads me onto my other question. How noticeable will it be for day to day usage if I downgrade to an i3? I don't want it to feel slow in comparison, however it's hard to gauge how it will perform for my needs as most reviews comparing i5/i3 tend to focus on gaming rather than desktop usage.
Another option is that I could wait for Ivy Bridge and make do with the 2500k for now?
). I agree it achieves this by reducing frequency and that it will be harder on the freq cut back than you, op, or I would be but it doesn't have the benefit of trial and error and has to work on the hoof. This solution certainly brings lower speed but has the advantage that the mobo is controlling the TDP.
