Nothing too special here, i can't find my old build thread so here is another.
I had previously built a new system into a Cosmos 2 case. Brilliant case, but limited places to store it, so decided to 'Switch' into a NZXT Switch 810. It seemed to be a fairly popular case so here it is. A few items including rads have change a little so...
Quick spec list:
i7 3770K @ 4.6
GTX 680 SLi @ 1200/1600
G1 Sniper 3
Kingston Hyper x 16gb
Corsair GS360gb SSD
2 x 1tb WD HDD's
XSPC RX360 Rad (mounted at the top)
Black ICE GT Extreme 280 Rad (mounted at the bottom)
Added some braided cables to the mobo and gpu's.
Changed coolant to Mayhems Pastel Blueberry.
Added two cathodes, one at bottom and one at top.
XSPC Dual bay res/pump.
5 140mm fans set in pull on both rads.
Now some pics.
Started by moving the base of everything into new case.
Nice thick rx360 ready to go in
Decided i would open up my EK Supremacy block and see what was lurking in there after a few months running on mayhems X1 UV blue.
All cleaned out, not much in there really. Tried using some MX-2 i had laying around this time, see how it goes.
Tight fit on the gt extreme rad, sat on top of the fans. Tubing all fitted. You can also see top rad.
Top rad fitted and then top fans added.
All new tubing, used XSPC tubing this time for a change from the masterkleer i used last time.
After some checking, filling, leak testing and final checks, all was good.
I suppose it will do for now....
Quick spec list:
i7 3770K @ 4.6
G1 Sniper 3
Corsair GS360gb SSD
2 x 1tb WD HDD's
Now some pics.
