- 28 Dec 2020
Hi,
Covid finally pushed me into building a PC. I overspecced a lot of parts and got some particularly quick ram. This was my first build and would have done things differently in hindsight.
16gb (2x8gb) Patriot Viper 4400. I am using a 5600x and wasnt happy at the default speed settings. I had done some basic research on the sticks and knew that buildzoid was creaming over them, i was also aware that they werent on MSI's approved vendor list, Patriots website clearly states that these are for use with intel chips only.
Tried using A-XMP @4400 and failed. So i used DRAM calc and plugged in some settings.
https://ibb.co/tBWw1H8
3800 16-16-16, manually set the fclck to 1900 and upped the voltage to 1.36 (0.02 higher than dram suggested).
After the xmp failed that was my first attempt, is it worth trying for tighter timings? would there be any noticeable difference with 3600 @ CL14? Should i try 3800 @ CL14?
Does the above look alright? !
Can you push fclck to 2000? or higher than 1900mhz?
Cheers.
Cheers.
