Patriot Viper 6GB DDR3 PC3-12800 (1600MHz) Low Latency (PVT36G1600LLK) Experiences?
23 Nov 2002
Near Bristol
not had an issue with mine so not sure about RMA.
XMP setup straight away @ 1600mhz and are fast as.
Got my i7 @ 4.2.
Spec & build in sig
would recomend
Thanks for the replies guys, sounds good.
Edit, Have placed an order! Just need the motherboard now.
@BigBruiserAl
Good to hear that I'm not alone in failing to OC these modules. The damn ClubOC review of this kit lead me to believe that 1866 C8 was on the menu but it's categorically not, I can't even squeeze 1650 out of them with the XMP timings.
I have read lots of reviews of this ram claiming decent overclocks, one was running C9 at 1900Mhz.. I hope they're right because I need 1780MHz minimum out of these...
Landed today...
Has a green PCB, thought it was meant to be black but no biggy.. Currently in my Foxconn X38A at 1780MHz, had to use loose timings to get it stable though.. So far so good!
What has a green PCB? :confused: The ram?
The circuit board is green, I'm sure they're black on the overclockers page and they are definitely black in the reviews I've been reading. It's no issue for me but I know some are picky about this sort of thing.
I'm going to try for 1868MHz tonight!
