PATRIOT VIPER STEEL 16GB 4400MHz ONLY £99 or 32GB 3200MHz ONLY £99 !!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well its Christmas and Patriot has delivered, wanting to strengthen their position within OcUK they have delivered a pair of mighty deals for OcUK customers:
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-35200C19 4400MHz Dual Channel Kit (PVS416G440C9K) @ £99.95 inc VAT https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g440c9k-my-103-pa.html
PVS416G440C9K, 4400MHz RAM Speed, CAS 19-19-19-39 Timings, 1.45v VDIMM, Lifetime Warranty with OcUK.
Only £99.95 inc VAT.
ORDER NOW
Patriot Viper Steel 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (PVS432G320C6K) @ £99.95 inc VAT https://www.overclockers.co.uk/patr...dual-channel-kit-pvs432g320c6k-my-106-pa.html
PVS432G320C6K, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
ORDER NOW
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-32000C19 4000MHz Dual Channel Kit (PVS416G400C9K) @ £79.99 inc VAT https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g400c9k-my-102-pa.html
PVS416G400C9K, 4000MHz RAM Speed, CAS 19-19-19-39 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £79.99 inc VAT.
ORDER NOW
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (PVS416G320C6K) @ £58.99 inc VAT https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g320c6k-my-105-pa.html
PVS416G320C6K, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £58.99 inc VAT.
ORDER NOW
With 3900X back to the original MSRP of £479.99 (new MSRP is £499.99 due to weaker pound), now is the time to make that upgrade, with some very tasty components indeed! :)
If a pair of these 4400 kits were paired up and downclocked to 3600/3733 (so as not to mess with the infinity fabric), what sort of timings do you think would be pretty easy to achieve without too much tweaking? Something like 16,16,16,36?
Any reason why you don't stock the 3733 Viper Steel?
3733 is not B die.
3866 upwards are B die and well I got the 4000 kits for less than 3866 so just made sense to stock the 4000 and 4400 models in B Die.
In theory the kits should down clock fine and if you get particular good IC than 15-16-16-35 can be possible at 3600 otherwise 16-16-16-36 or if again you get unlucky then 16-18-18-42 all at 3600.
Always remember to fine tune other sub timings too and use Ryzen master.
I bought the Patriot Viper Steel 4000MHz DDR4 PVS416G400C9K last week and this is what Thaiphoon burner gives me about the memory:
Manufacturing Description
Module Manufacturer: Patriot Memory
Module Part Number: 4000 C19 Series
DRAM Manufacturer: Samsung
DRAM Components: K4A8G085WB-BCPB
DRAM Die Revision / Process Node: B / 20 nm
Module Manufacturing Date: Undefined
Module Manufacturing Location: Taipei, Taiwan
Module Serial Number: 00000000h
Module PCB Revision: 01h
Physical & Logical Attributes
Fundamental Memory Class: DDR4 SDRAM
Module Speed Grade: DDR4-2133P downbin
Base Module Type: UDIMM (133.35 mm)
Module Capacity: 8 GB
Reference Raw Card: A0 (8 layers)
JEDEC Raw Card Designer: SK hynix
Module Nominal Height: 31 < H <= 32 mm
Module Thickness Maximum, Front: 1 < T <= 2 mm
Module Thickness Maximum, Back: T <= 1 mm
Number of DIMM Ranks: 1
Address Mapping from Edge Connector to DRAM: Standard
DRAM Device Package: Standard Monolithic
DRAM Device Package Type: 78-ball FBGA
DRAM Device Die Count: Single die
Signal Loading: Not specified
Number of Column Addresses: 10 bits
Number of Row Addresses: 16 bits
Number of Bank Addresses: 2 bits (4 banks)
Bank Group Addressing: 2 bits (4 groups)
DRAM Device Width: 8 bits
Programmed DRAM Density: 8 Gb
Calculated DRAM Density: 8 Gb
Number of DRAM components: 8
DRAM Page Size: 1 KB
Primary Memory Bus Width: 64 bits
Memory Bus Width Extension: 0 bits
DRAM Post Package Repair: Not supported
Soft Post Package Repair: Not supported
DRAM Timing Parameters
Fine Timebase: 0.001 ns
Medium Timebase: 0.125 ns
CAS Latencies Supported: 10T, 11T, 12T, 13T,
14T, 15T, 16T
Minimum Clock Cycle Time (tCK min): 0.938 ns (1066.10 MHz)
Maximum Clock Cycle Time (tCK max): 1.500 ns (666.67 MHz)
CAS# Latency Time (tAA min): 13.500 ns
RAS# to CAS# Delay Time (tRCD min): 13.500 ns
Row Precharge Delay Time (tRP min): 13.500 ns
Active to Precharge Delay Time (tRAS min): 33.000 ns
Act to Act/Refresh Delay Time (tRC min): 46.500 ns
Normal Refresh Recovery Delay Time (tRFC1 min): 350.000 ns
2x mode Refresh Recovery Delay Time (tRFC2 min): 260.000 ns
4x mode Refresh Recovery Delay Time (tRFC4 min): 160.000 ns
Short Row Active to Row Active Delay (tRRD_S min): 3.700 ns
Long Row Active to Row Active Delay (tRRD_L min): 5.300 ns
Long CAS to CAS Delay Time (tCCD_L min): 5.625 ns
Four Active Windows Delay (tFAW min): 21.000 ns
Maximum Active Window (tMAW): 8192*tREFI
Maximum Activate Count (MAC): Unlimited MAC
DRAM VDD 1.20 V operable/endurant: Yes/Yes
Thermal Parameters
Module Thermal Sensor: Not Incorporated
SPD Protocol
SPD Revision: 1.0
SPD Bytes Total: 512
SPD Bytes Used: 384
SPD Checksum (Bytes 00h-7Dh): 6355h (OK)
SPD Checksum (Bytes 80h-FDh): B2ADh (OK)
Part number details
JEDEC DIMM Label: 8GB 1Rx8 PC4-2133P-UA0-10
Frequency CAS RCD RP RAS RC RRDS RRDL CCDL FAW
1067 MHz 16 15 15 36 50 4 6 6 23
1067 MHz 15 15 15 36 50 4 6 6 23
933 MHz 14 13 13 31 44 4 5 6 20
933 MHz 13 13 13 31 44 4 5 6 20
800 MHz 12 11 11 27 38 3 5 5 17
800 MHz 11 11 11 27 38 3 5 5 17
667 MHz 10 9 9 22 31 3 4 4 14
Intel Extreme Memory Profiles
Profiles Revision: 2.0
Profile 1 (Certified) Enables: Yes
Profile 2 (Extreme) Enables: Yes
Profile 1 Channel Config: 1 DIMM/channel
Profile 2 Channel Config: 1 DIMM/channel
XMP Parameter Profile 1 Profile 2
Speed Grade: DDR4-4000 DDR4-3868
DRAM Clock Frequency: 2000 MHz 1934 MHz
Module VDD Voltage Level: 1.35 V 1.35 V
Minimum DRAM Cycle Time (tCK): 0.500 ns 0.517 ns
CAS Latencies Supported: 20T,19T,18T,17T,
16T,15T,14T,13T,
12T,11T,9T 23T,22T,21T,20T,
19T,18T,17T,16T,
15T,14T,13T,12T,
11T,9T
CAS Latency Time (tAA): 19T 18T
RAS# to CAS# Delay Time (tRCD): 19T 22T
Row Precharge Delay Time (tRP): 19T 22T
Active to Precharge Delay Time (tRAS): 39T 40T
Active to Active/Refresh Delay Time (tRC): 68T 68T
Four Activate Window Delay Time (tFAW): 24T 24T
Short Activate to Activate Delay Time (tRRD_S): 6T 5T
Long Activate to Activate Delay Time (tRRD_L): 4T 4T
Normal Refresh Recovery Delay Time (tRFC1): 700T 677T
2x mode Refresh Recovery Delay Time (tRFC2): 520T 503T
4x mode Refresh Recovery Delay Time (tRFC4): 320T 310T
Show delays in nanoseconds
3733 is not B die.
Yeap, I realize 3733 is not B-die but as far as I gather it's the perfect speed for Ryzen, a touch better than 3600.
Still undecided whether to get some 4400 and downclock with better timings or just buy the 3600/3733 and leave it. Both the Viper Steel 3600/3733 have very reasonable stock timings and I'm really not into tweaking that much where RAM is concerned. The 8Pack would be better but I guess I've missed the boat on any deals for that RAM this side of 2020.
The 4400 Viper downclocks rock solid to C14 at 3600.
It runs exactly the same memory settings as my 8 pack set.
However the Vipers show as 94% quality to 92% for the 8 pack set.
Thaiphoon burner shows tighter timings from the Viper set though.
The none B die vipers don’t clock or tune as well.
Better of buying 4000 or 4400 Vipers and then down clocking them to 3600-3733 with as tight as you can make the timings.
Sick of procrastinating so will go with the Steel 4000Mhz. I'm not looking for uber fast timings and something like 16,16,16,36 will be great or even 16,19,19,39 is fine @3600Mhz (motherboard is an X570 Aorus Master). Not sure if I'm using Ryzen Calculator right but that seems to say those are possible using just its Safe preset (using Superficial's info from above). Not a major gamer and I understand timings make the most difference in games, so it's not essential to get every last drop out of the RAM. Thanks for your help.
I'm not experience at all but I got 15, 15, 15, 35 @ 3733 by just adjusting a couple of things so you'll be grand.
That's good to know, I'll see what it can do when the system goes together at Christmas. I'm not too experienced in RAM overclocking either so getting those timings with just a few adjustments sounds sweet.
These will easily do 3600 at cl14. The 8 pack 3200cl14 kits are a slightly lower bin and will all do this (cpu dependent I guess).
Got the cheap Patriot 16GB 3200MHz kit running at 3400MHz with same main timings and a slight touch up to 1.39v on the DRAM (XMP had it on 1.376v). 1700/1700 FCLK & UCLK. Not bad for what it is. Manufacturer showed as being "Nanya" in Taiphoon Burner (it's an older freeware version, may not be as good/accurate).
You're possibly right but dram calculator shows my VS 4000 as 86% and my best settings as 3783 @ CL 16
I wonder if anyone knows if that is the safest bet or really my most reliable performance settings? I was running 3733 @ cl15 stable but I realisd my Tomahawk max onboard audio was crackling and popping - this was definately beause of my ram settings but since using Drams settings (properly this time) the beow is a far beter result than I was getting before:
h4nY2rq
h4nY2rq
Oh really, 86%??? That doesn't sound right, just checked and my 8 pack show as 93% and I have had them running at 3800 cl16 too :S
I've read that the audio crackle is when you're running above the fabrics silicon quality, I would shoot for 3600 cl16, then try and tighten to cl14 if all goes smooth.
ok mate will try that cheers,
I'm certainly not done with experimenting but I *think* my aida benchmark results are pretty decent even at 3733/CL16
