** Payday Motherboard Blow Out! **
OcUK Systems
OcUK Staff
16 Nov 2007
Stoke-on-Trent
If you are in the market for a new motherboard, now is the time! We have loads of motherboard deals for this week only, many of which also qualify for Intel's Cashback promotion!
Here are just a few of our best deals!
Asus Rampage V Extreme Intel X99 (Socket 2011) DDR4 EATX Motherboard @ £329.99 inc VAT
Was £352.99 Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Gigabyte X99-UD4P Intel X99 (Socket 2011) DDR4 ATX Motherboard @ £179.99 inc VAT
Was £192.95 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Asus Maximus VII Impact Intel Z97 (Socket 1150) DDR3 Mini ITX Motherboard @ £169.99 inc VAT
Was £179.99 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Gigabyte X99M-Gaming 5 Intel X99 (Socket 2011) DDR4 Micro ATX Motherboard @ £157.99 inc VAT
Was £169.99 Inc. VAT
Only £157.99 inc VAT.
ORDER NOW
Gigabyte Z97X-UD3H-BK Intel Z97 (Socket 1150) DDR3 ATX Motherboard @ £112.99 inc VAT
***ALSO QUALIFIES FOR GIGABYTE'S FREE UPGRADE PROGRAM!!! ***
Was £124.99 Inc. VAT
Only £112.99 inc VAT.
ORDER NOW
Gigabyte Z97X-SOC Intel Z97 (Socket 1150) DDR3 ATX Motherboard @ £104.99 inc VAT
Was £134.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Is the Rampage V Extreme the (RAMPAGE V EXTREME/U3.1) the refresh with the USB3.1 version? if it is I think I will go for it?
Do you stock that refresh version at all anyway?
It's not, since the "refresh" simply has a bundled Asus 3.1 card. Something which I'll have for sale shortly anyway. Seems silly to have two identical boards listed at the same time.
So does this mean I should hold off buying this now then if I am interested in acquiring the USB 3.1 connection (I don't want to pay extra if it comes included)?
Honestly, USB 3.1 is currently a bit pointless but I'm still a bit disappointed that Asus didn't follow MSI's lead and put it properly on the board.
Depending on your VGA/add in configuration and your CPU, you should consider whether the USB 3.1 card will use PCI-Express lanes that are needed for other devices.
If you want the card with this board then it's probably best to get the bundle, however, please bear in mind that the bundle is more expensive, although, I believe, still a little cheaper than buying the card separately.
Thanks for the info. Appreciated.
