pc advice problems
26 Feb 2009
Hi,
Need a bit of advice. My pc keeps crashing when i try to play games.I have put in a new psu 500w which is ample as the old one was 300w from new.I havent changed any hard ware or memory its as it was when i bought it.I have run memtest and taken out the stick or memory and reseated it in another slot and reran memtest every thing is ok.Changed the drivers for the card cleaned the pc of dust.
My system is P4 3.4 prescot 512 ram fx 5500 and its a fijitsu seimens pc.All temps are ok when running it as i have checked in the bios and other software.This is the first error i get in the event log
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 01/03/2009
Time: 12:38:26
User: N/A
Computer:
Description:
Error code 1000007f, parameter1 00000008, parameter2 f8b15d70, parameter3 00000000, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 37 1000007
0020: 66 20 20 50 61 72 61 6d f Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 30 38 2c 20 000008,
0038: 66 38 62 31 35 64 37 30 f8b15d70
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 30 30 30 30 00, 0000
0050: 30 30 30 30 0000
the second one i get is
Event Type: Error
Event ID: 1003
Date: 27/02/2009
Time: 17:47:53
User: N/A
Computer:
Description:
Error code 1000007f, parameter1 00000008, parameter2 80042000, parameter3 00000000, parameter4 00000000.
Data:
0038: 38 30 30 34 32 30 30 30 80042000
These are blue screen errors it only seams to happen when i try to play a game and the pc screen turns it self off any ideas thanks.
Yea thats why i changed it i had the new supply checked before i came home with it as i needed a new one as the other pc i got the psu has blown on there lol but thats another stoy lol.I have also tryed to put in a card from my old pc which is 8 years old and the card is a ti 4200 in ther but not sure if its compatable tbh as its older.
The problem has got worse tbh over the last few weeks i got the new psu last week every thing else is working ok i can watch things on the net ok but no games even the old games like diablo i cant play as the screen flashes black and i get numbers in the left corner also in wow i get the scren flashing blank and then crashes.I was able to play cod 2 but i cant play that now as i either get a blue screen or no signal on the lcd monitor but the pc is still on.
I have down loaded a diag tool from fujitsu and as soon as it gets to the graphics test the pc goes again.At the momment Everest is saying the cpu temp is 53c but the bios was saying 74c. I did a few years ago have a problem with the cpu temp and as it was under warranty i had that fixed needed new thermal paste but it is not as high now as it was then as it was going to 90 odd c and i could play games just the pc would switch off.
specs P4 3.4mhz 512 ram 200gb hard drive tryed a few drivers been lookig around the net for a few weeks abou this and on the nvidia forums.GFX CARD fx 5500 8x agp.I have another card but not sure if its working s the other pc i have blew lol but its an older one ti4200 i bought it from overclockers and had no probs with it lovely card for the time lol.I have tryed it but i get beeps so not sure it works or compalable.
Thnks for that info i have tryed and downloaded the last update for directx 9 as im running xp on here as i thought dx10 was for vista only.I had a look for bios updates and what it said was that the only it only updated the sata driver but i havent got that inuse anyway.Strange thing is my old pc which blew was a lot older 9 years old infact and ran WOW Half life2 with older drivers as the card was older with np at all thats what i think is strange even after the last patch from WOW which had an update for the nvidia cards the older pc ran it np bit laggy but it was older.This pc no wont run a thing lol
I think it is the card to tbh ill have a quick look in the bios now and see what it says and come back as it has bn on for a bit.
bios update cpu temp 59c last temp i gave of 72c was after running memtest.I have updated the drivers taken out the card resloted the card cleaned everywhere.Also i forgot to say,wife reminded me, the prob with the screen flashing blank had happened over a few months but only now and again in wow and the screen would have no signal message so had to switch off and reboot and all ok but it would only happen now and again.
Windows is up to date with drivers i have update on.Graphics drivers i have tryed a few old ones new ones and cleaned out previous drivers before adding new ones.
ah looooooool tbh cant see it being the monitor as the blue screen errors are hardware related thats what i get the jist of the strings meaning but i have tryed anothe monitor yes.
I hink so to may go and get one now and do as you say lol doing my head in now tbh havent played wow for 5 weeks lol
The shop i could take it to said it maybe the card but could be anything lol but prob is i an do that myself but he says he has all the stuff to stress test it there to pin point the prob.
I know what your saying m8 lol im not that dumb with pcs but he just wanted he business i think.lol i got a agp x8 slot on the board not much cash to spend atm i like to play WOW tbh not much else untill i can afford to build a new system in the future so what do you sugjest to buy.I got an fx 5500 in here now and can play wow but was starting to feel the strain.
ok i got agp x8 slot i like WOW thatd the game i play as the rest of the pc isnt up to new games will build one in the future hopefully.At the momment i got an fx 5500 in here runs wow ok and i havent got a lot of cash at the momment any ideas.
