Hi all, I hope I can get some advice from yourselves about what I might be doing wrong with my build and where I might get some improved performance. I guess it might be useful to give you all a summary of my build to get things started:
Mobo - Asus x570 tuf gaming +WiFi
CPU - 5950X (water cooled with Arctic Liquid Freezer ii 420 aio)
GPU - PNY 3090 XLR8 (water cooled with alpha cool Eiswolf 360 aio)
RAM - 64GB Corsair 3600mhz
Power supply - Corsair RM1000e
Case - phantecs G500A
Right, so I've had ongoing system instability issues since before I decided to watercool my GPU and even with my previous 3070 GPU I'd have frequent crashes in otherwise simple games, like fortnite. I've downloaded HWInfo and noticed that at its peak, my GPU memory junction temperature can reach up to 90°C but I'm unsure if that's the cause for the crashing. Also, I'd be interested to know if my card fan configuration is ok:
I've got 3 120mm intakes at the front
3 140mm (slim) exhausts at the top
1 140mm intake rear.
Is this enough positive air pressure?
Any advice would be amazing, and thank you for those of you that got this far, appreciate your time!
Monitor too. Sorry I'm not helping... But CPU probably overkill
