PC and subwoofer vibrations
11 Oct 2011
UK
Hi all,
Not really sure where to post this so thought I'd put it here
I recently moved my subwoofer from behind my TV (as it was rattling some of the wires and making an annoying noise) to underneath my desk (to a part where there's no wires)
As it's now nearer to my PC, if I put my hand on the PC case I can feel the vibrations through it
Is this something I should try and stop? Or will it be OK?
Any suggestions of anything to put under the sub / pc to reduce vibrations?
Hope you can help, :)
If they don't work, google "AcoustiFeet Vibration-absorbing Low Profile Silicone Feet", or "Scythe Device Stabilisers".
Think both are made of silicone rubber and are very good at stopping vibrations.
Not too sure if you have resolved this problem of yours but I'll through in my 10cents worth.
Many audiophiles use spikes to seat there speakers on. This is to damper un wanted vibrations. you can get them in many different sizes and heights, and typically they are full metal construction.Heres a photo just to give you an idea what they look like. google them for more info.
Hope this helps
Hope this helps
Sorry, only just saw this
I am going to try the furniture pads for now, haven't got round to it yet lol, been busy, will go get them now :p
I put some of those pads under the subwoofer and I think it has reduced the vibrations a bit
It has proper feet on the bottom, but I think it was vibrating things more because to put it under my desk, I had to turn it on its side, so the side of the sub was just sitting on the wooden floor.
Now it is raised a bit I think it is better
