- 29 Aug 2010
- United Kingdom
Hi guys,
So recently just repasted my AMD CPU from my HTPC as it was looking a bit dry and crumbly (my fault I don't replace it often enough) put some arctic silver on that I had lying around and reseated as usual, However. Now I am getting absolutely nothing out of the PC. I have checked that its not the cables or the monitor its connecting to by trying all 5 of the monitors and tv's and nothing seems to work. So its gotta be something to do with the PC itself,
The build spec is in the HTPC log in my sig.
I have tried removing and cleaning everything, re-seating all the ram, hard drives, and pretty much everything else, I noticed there was a slight bit of paste on one of the pins when I removed it and so I wiped it with some tissue and put it back in, I wasn't sure if there is a specific cleaning tutorial for cleaning the CPU pins? I was thinking maybe a dab of Isopropyl alcohol would do the trick surely?
None of the pins are the bent, the socket looks fine, I'm tearing my hair out without my HTPC, I use it everyday and every night.
EDIT: The PC does boot, and the hard drives and everything are spinning up. just no display output whatsoever.
Has anyone got any advice?
