PC build - Advise needed
19 Nov 2005
hi,
I am currently in the process of building myself a new computer but im slightly unsure about compatibility of components, This is my first time building a computer completely from scratch and due to my budget I cant afford to purchase incorrect components. I know what I want im just unsure of compatibility, below is a list of what im hopping to put together, me and my dad have had a look and it looks ok to us but if anyone have the time could they give this a quick look to confirm that it will all work nicely together.
CPU - Intel Pentium 4 650 (3.4 GHZ)
MOBO - Abit AW8 Intel 955x
CPU cooler - Thermaltake Blue Orb II
HDD - Western Digital Caviar Special Edition 200GB 2000JS
Graphics - Sapphire ATI Radeon X800 GTO (GX-118-SP)
RAM - (Advise needed)
Ok, that's all of the main components im hoping to use, but I am unsure of what type of RAM is needed. I would like 1GB and I don't mind if its a 1GB stick or 2 512 sticks. I have around £70 to spend but I can probably spend a little more if needed. I am pretty comfortable with all the other stuff needed, I have already got the case and PSU and I have a few other things such as CD drives lying around the house.
Any useful feedback would be great appreciated
Thanks -Magnumwolf-
i second that, spending 240 quid on a 3.6 ghz p4 chip that would give less performance then a similarly priced AMD chip. Clock Speed isn't everything :)
Could you suggest a better set up? The computer will be mainly for gaming.
I mainly chose P4 as ive never actually used AMD before, No idea how to compair them with pentium. :)
how about something like this -
MB-088-AS Asus A8N-E nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-088-AS)
£59.95 £59.95
CP-150-AM AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM)
£119.95 £119.95
MY-046-GL GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3 (GE2GB3200BDC) (MY-046-GL)
£94.95 £189.90
HD-048-WD Western Digital Caviar Special Edition 200GB 2000JS SATA-II 8MB Cache - OEM (HD-048-WD)
£49.95 £49.95
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)
£15.95 £15.95
GX-061-PC PowerColor ATI Radeon X1800 GTO 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-061-PC)
£134.95 £134.95 (This Week Only)
Subtotal £570.65
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £8.95
VAT £101.43
Total £681.03
Would be a lot faster then the pentium rig :P
If its too high for your budget, then you could cut down ram and gfx and get -
£59.95 £59.95
£119.95 £119.95
£49.95 £49.95
£15.95 £15.95
MY-005-GL GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
£49.95 £49.95
GX-055-PC PowerColor ATI Radeon X800 GTO16 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-055-PC) (This Week Only)
£69.95 £69.95
Subtotal £365.70
VAT £65.57
Total £440.22
Could be wrong but the gfx card you chose doesn't have the bandwidth to really make full use of its 512mb
£59.95 £59.95
£119.95 £119.95
£94.95 £189.90
£49.95 £49.95
£15.95 £15.95
Subtotal £570.65
VAT £101.43
Total £681.03
£59.95 £59.95
£119.95 £119.95
£49.95 £49.95
£15.95 £15.95
£49.95 £49.95
£69.95 £69.95
Subtotal £365.70
VAT £65.57
Total £440.22
both of these rigs are far better than the original Intel spec. especially for gaming. personally id go for the top one.
£59.95 £59.95
£119.95 £119.95
£94.95 £189.90
£49.95 £49.95
£15.95 £15.95
Subtotal £570.65
VAT £101.43
Total £681.03
I vote this spec, but I dont think he needs 2 x 2gb dual chan kits :p
Thank you all for the advise
Will run it past my dad, see what he thinks but i am happy with what you have shown me and as you have all said AMD is much better i will believe you :p
Will give it a good look over, and probably order it all tomorrow.
Thank you all very much
Any suggestion of a more funky looking fan? Im also case modding this comp so fans withs lights are good :p
Or would you say that your recommendation over more superior cooling?
-Magnumwolf-
I recently made the move from a 3.6GHz P4 to the AMD platform and would definately recommend the transition (if, like me, you've never owned a AMD rig before :D )
The 3700+ is a fantastic processor at a really excellent price
