PC Build check / advice 1440p gaming
Guys, not sure if you can help. I'm thinking of going down the custom route for cable sleeves, but it's quite difficult finding anywhere reputable that do them. I see a lot of negativity toward the Cablemod ones.
Any options out there for the MSI PSU?
Thanks
I finished the build last night, such an easy and spacious case to work with!
Probably a bit boring for most but I just like the simplicity without colour or RGB and the fact that it's a very powerful machine!
Rich (BB code):
Not boring at all, I hate RGB and will avoid it at all costs lol
glad its all built
i used to think the same,,,now my tower, keyboard and mouse are all rgb-blinged out :cry:
I have it disabled when possible.
Keyboard is back lit with 1 solid colour which I like as makes it easier to see keys, Mouse has it disabled, motherboard has it disabled, GPU has the cable disconnected for it and the case does not have any nor does the ram.
Rich (BB code):
ah a lan cool 3? dad and i done builds on them and they are a awesome case to work on, nice nooking build :)
