Hi my 18 month old build is :-
ROG STRIX X570-F GAMING Mother board
AMD Ryzen 7 5800X 8-Core Processor, 3801 Mhz, 8 Core(s), 16 Logical Processor(s)
Installed Physical Memory (RAM) 64.0 GB
AMD Radeon RX 6700 XT
Main board and CPU is water cooled and GPU fan cooled, with 6 4" fans.
All games have no problems but one game overheats my PC
I have followed youtube video`s of configuring the GPU and I got an extra 30% out of it.
Though the CPU still seems a little hotter than usuall.
2month`s ago I had the PC stripped, cleaned, fresh fluid and fresh paste. Also full bios update.
About a month ago I accidently updated the BIOS and I think this messed up my water cooling. I did this before just after the build, and after taking it back to get it checked, the updated BIOS reversed the cooling system on my PC, as I started to get a lot of crashes and freezes.
Im asking, how do I check my pump settings in bios and adjust so they function properly? I did have a look but cant make head`s or tail`s of it.
Also are there any apps that can be used in windows 10 that I can easily adjust and monitor the pump settings and temp?
I can adjust the GPU fans with Adrenalin app.
Current issue is the CPU temp has gone from 60 deg C to 70-75 deg C, this 15c jump seems to cause a shut down after an hr or so at constant temp jump. At 60 no issues. And assuming the pump needs readjustment if my BIOS update changed the settings.
Thanks
Thanks
