PC build for video editing
16 Jan 2021
Hi,
Im looking for a new PC to primarily edit movies. Only HD rather than 4k. Plan to use Cyberlink Power Director.
I currently have an Intel i5 2.67GHz CPU, 8GB Ram with a ATI radeon hd 5450 graphics cards and performance when editing is awful - it will fail to preview any edits before producing the movie.
I have a budget of £500. Should I be prioritising budget to the graphics card over everything else? Grateful for any advice and suggestions.
Many thanks
It's very unlikely that power director will utilise a high threaded cpu. You'll need to research what the program is cable of first. No point buying an 8 core cpu if it only uses 2.
Thanks both.
They recommend an Intel Corei5 or AMD Phenom II X4 and above - but dont mention speeds or cores. I note extra cores do not necessarily mean extra speed ie you could have an i7 with 8 cores and then an i5 with less cores but more GHz than the more expensive i7!? Difficult to know which are more important - GHz or cores
Program uses multi threading so any current Intel / ryzen 6c/12t will be a big upgrade. Personally would so Resolve is a better program to use as its faster and uses any hardware you got better .
Out of stock but give you an idea . Onboard GPU to cut down costs of GPU unless you have one . Again resolve uses GPUs better
My basket at Overclockers UK:
Total: £314.47 (includes shipping: £10.50)​
According to a 2017 post, it'll use as many cores as you can throw at it. In 2021 money, that means 8 cores would be a smart choice. It also supports cuda (gpu acceleration), so you'll want to check how much of a difference that makes to see where the money is best spent.
8c cpu will likely to bust your budget. Even 3700x is around £280-£300. Earlier zen cpu like 2700x is probably not worth it as you are loosing a fair bit of performance.
intel 8c parts 10th gen is just not great value either.
stick with the 10400 CPU and the board previous specced and add to it a GTX 1650 or 1660 GPU for graphic acceleration. That should be within you £500 budget.
if you shop around rather than rely on OCUK you should be able to afford 32GB of ram with CPU motherboard and GPU for under £500.
Hi,
Many thanks
i7 8 core 16 threads can be done
Total: £500.46 (includes shipping: £10.50)
mentioned in another thread US slashed prcing of 10850k 10 cores to $400 , which under perfect conditions would have been £310.... but never going to happen for so many reasons currently.
*mobo and ram out of stock but is a good hint for what would work​
with you original spec, he can have a GTX GPU which will be better for him as video editing has a lot of effects that can be accelerated by CUDA. though i dont know details about that particular software
davinci resolve is so much better, free as well but lacks features of paid version. that would use hardware/gpu so much better.
seems most using Cyberlink running CPU acceleration
many thanks for your time and suggestions - it's much appreciated.
I hadn't heard of Resolve so will certainly look into it if it makes better use of hardware performance.
The GTX 1650 or 1660 GPU looks a good investment, I guess I just then need a CPU with as many cores as I can afford.
Will have a shop around. Not sure I'm confident building anything from scratch so if you're aware of anything pre-built that may fit the bill, please share. Thanks again.
best build yourself, if going Pure gaming- you'd be forced to buying pre-built due to GPU stock issues
Build yourself. Watch a few YouTube videos if you have never done a build or put a component into a PC before.
It is not rocket science.
if something doesn’t go right after the build and you can’t fix it then you can always take it to your local PC shop for a bit of diagnostics and pay them some money do the troubles and it will still work out cheaper and better than pre-builds
