pc build graphics help....
27 Oct 2011
hi guys i was just wondering if someone could just help me out with a query i have,what graphics card should i be putting into my Asus M5A78L-M USB3 AMD 760G AM3+ mATX motherboard and what i can put in it im looking to make my build for blu ray movies a few key games, warcraft and football manager i have a phenom 2 955 be, my budget to be honest is £70 max really i could stretch to 80 but dont really want to any help would be a great help, many thanks
Hey dude I've recently built my PC tht seems a bit similar to urs in terms of mobo and CPU.
Do u currently have a Blu ray drive?, graphic card wise I would go for this which will handle the games no prob(also on weekly deal aswell). AMD cards seems to work better with AMD CPUs.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-264-AS&groupid=701&catid=56&subcat=1982
but if u wanna go with Nvidia this is great choice:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-265-AS&groupid=701&catid=1914&subcat=1576
costs a bit more though. Both by Asus coincidentally
i was about to recommend the GTX 460 refurb but it seems to have disappeared from the shelves. shame that because its way better than anything else thats been recommended and would have been perfect for you
