Are you using XMP for the ram settings, as this will automatically set the voltage at 1.65v.
You may need to manually set the voltages.
I know nothing about RAM settings. My knowledge of computers is next to nothing apart from the odd term. Is it easy to set the voltages manually?
can you use a HDTV for the time being? would save some cash to actually spend on improving the parts in the spec![]()
I will be using a HDTV. I've ended up spending more than I intended on the parts anyway (and that's without a monitor) but it'll be well worth it. I ordered the last of the parts last night so I'll hopefully be able to put it together tomorrow afternoon.
Hopefully nothing goes wrong and, assuming I don't end up needing any further help/advice, I'd just like to say cheers everyone for the help! It's quite daunting spending so much money on something you know barely anything about but everyone on here has been so helpful.
Did you manage to sort the ram voltages out?
The XMS3 will run at 1366Mhz on default settings at 1.5v, so the computer will work ok.
But, to get it to run at 1600Mhz, you will need to do it manually, as XMP will automatically set the voltage at 1.65v.
Have you bought the ram with the new system or did you already have it?
Are there no instructions with the case?
Not really, no. I plugged the side panel fan into "sys fan 3" and that runs fine. I rang technical support up but because they were closing at 2 he said he'd have to pass it on for someone to help on Monday. I'm still using the computer with the one fan running since the case is massive so should have a reasonable air flow in it but I want them sorted asap if I can. Do you have any idea what adapter it may be? The only way I can describe the cable is it being a three pronged wire. Instead of the end being one that allows you to insert the three prongs into it, it's the end that has the three prongs coming from it. I'm guessing I need a cable with the female connector on both ends?
There is also a 4-pin Molex power connector to power the fan controller and a fan cable for attaching the side panel fan to.
This should help explain things a bit, hopefully. So, that 3 pin connector from the controller is for the side fan. The rest of the fans will work once you have connected the molex cable to a molex connector on your Psu.
I just can't seen the molex cable anywhere.
Can you see the back of the controller and see if there is a port for a molex connector.
