- 1 Feb 2009
- The Zooniverse
I was wondering if anyone of you wise men could shed some light on a small problem of mine.. i upgraded my own pc,so i decided to use all the old parts to build a pc for my brother.I installed everything into the case,but when i power on the pc,i can get past the bios screen,but then i get this message:
PXE-E61 : Media Test Failure,check cable
PXE-M0F : Exiting Intel Boot Agent
Disc Boot Failure.. insert system Disc and Press Enter.
I've double checked the cables,which are new.. and i've tried it with two different Hard drives.. with the same results.
I'd be grateful for any ideas or advice on how to solve this problem.
Dan
Dan
