hey i have got a build here:
CPU: AMD FX6300 Black Edition 6 Core (3.5/4.1GHz, 8MB L3 Cache, Socket AM3+)
Motherboard: Asus M5A97 R2.0 Motherboard (AMD 970/SB950, 4x DDR3, S-ATA 600, ATX, PCI-Express 2.0, USB 3.0, USB BIOS Flashback, Socket AM3+)
CPU Cooler:Cooler Master Hyper TX3 Evo Tower Cooler for CPU
Graphics Card: Asus R9280X-DC2T-3GD5 1070MHz 3GB GDDR 5 PCI Express Graphics Card
RAM: Kingston Technology HyperX Beast Series 8GB 1600MHz DDR3 CL9 Desktop Memory Module (Kit of 2)
HDD: Western Digital 1TB internal Hard Drive – Caviar Blue (3.5 inch)
PSU: Corsair Builder Series CXM 600W Modular 80 PLUS Bronze Certified ATX/EPS PSU
and i need advice on a medium tower case that supports atx motherboards and can fit a 29cm graphics card. And preferably has good cooling or a lot of pre installed fans as i cant stretch my budget as of yet to buy more fans to put in. also if it looked smart with the occasional led here and there
thanks for all the help and one last the the budget for the case is £55
For OP though you can't really do better than that for £35
