PC Case's for under £55 help
I have one, although I would probably advise against getting it. It's decent enough for the money but it splits opinion on looks (a personal thing i guess) and for me it doesn't have a good enough feature set compared to the competitors in the same price range. If I could do my build again i'd probably get something else.
Here's mine so far managed to the best of my ability.
http://forums.overclockers.co.uk/showpost.php?p=26370179&postcount=3833
What one would you rather get cos I am having trouble finding ones that can fit a 28.7 GPU and that looks nice with a window for £70
If you can stretch another £10 I'd probably go for this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-068-CS&groupid=2362&catid=2277
Otherwise these two are within budget and are feature packed, good cases:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-129-BX&groupid=2362&catid=2277 &
http://www.overclockers.co.uk/showproduct.php?prodid=CA-100-CS&groupid=2362&catid=2277 (someone mentioned this one earlier in the thread)
Corsair 230T is also another good option. One of those cases that gets overlooked but has a lot going for it. Especially on a budget.
Enthoo Pro or 450D is what I would be looking at. Maybe the Fractal Deisgn R4 (not sold at OCUK) which is also available with a side window.
What can I run with this build? ?
CPU: AMD FX6300 Black Edition 6 Core (3.5/4.1GHz, 8MB L3 Cache, Socket AM3+)
Motherboard: Asus M5A97 R2.0 Motherboard (AMD 970/SB950, 4x DDR3, S-ATA 600, ATX, PCI-Express 2.0, USB 3.0, USB BIOS Flashback, Socket AM3+)
CPU Cooler:Cooler Master Hyper TX3 Evo Tower Cooler for CPU
Graphics Card: Asus R9280X-DC2T-3GD5 1070MHz 3GB GDDR 5 PCI Express Graphics Card
RAM: Kingston Technology HyperX Beast Series 8GB 1600MHz DDR3 CL9 Desktop Memory Module (Kit of 2)
HDD: Western Digital 1TB internal Hard Drive – Caviar Blue (3.5 inch)
PSU: Corsair Builder Series CXM 600W Modular 80 PLUS Bronze Certified ATX/EPS PSU
E.g can I run games like arma 3 on high and BF4 on high ect ???
You should be alright, just. Your CPU might draw you back somewhat though. If I were you I'd spend the extra money that you were going to spend on a case and grab an FX-8 8350 instead, just for an extra few frames per second.
