PC Cooling Issue - Help!
19 Oct 2002
Liverpool, UK
I have what I suspect to be a cooling issue similar to the one recently posted here. I too have been fine with games that don't really tax my hardware, but then when anything remotely fancy was played, my PC would lock up - I'd see a screen filled with coloured bands, but still hear game sounds in the background as if everything was OK.
I assumed that it was a dodgy graphics card, which I replaced - swapped a 5870 for a 7970, and all was well. Obviously, the previously taxing games on the 5870 were a breeze on the 7970, so it looked like things were fixed.
Until I'm now trying some games that tax the 7970 a little, and the problem has returned.
I have;
i7 930 at stock 2.8GHz
Gigabyte GA-X58A-UD3R
6GB of Patriot Viper 1600MHz
HIS HD 7970 IceQ X² GHz Edition 3GB
Be Quiet! Dark Rock Advanced Cooler, stock fan
Fractal Design Define R4
Initially, I could play taxing games for around 5 minutes before things locked up.
Took off the side panel, things lasted a little longer, perhaps an hour or so? Then, same symptoms.
I've since gone raiding my old parts box upstairs, added a side 120mm fan and a top 120mm fan, but they're running at full pelt no matter how I set them up in the BIOS. With the room door open for ventilation, I can play games for hours now, but it sounds like I'm sat next to a tumble drier.
What would you consider my best option to be? Right now, graphics card is maxing at 65C during games from what I can see, but the air coming out of the case feels pretty warm to me.
No idea if I'm better getting some better fans and a decent fan controller, then trying to figure out how best to set it up for intake/exhaust. I'd be quite happy cranking up the noise for some stable gaming, but I'd want to turn down the noise when I just want desktop access.
Not really sure where to turn, starting to doubt my own build skills now - considering I put the original machine together almost 3 years ago now, despite an overhaul it's still causing me problems. If it wasn't for the new 7970 I'd be giving up and opting for a new machine built my OcUK, and not me!
are you monitoring cpu temps?
still shouldn't lock up imo,even if it was running hot
setting ati power control slider to 20% in ccc? and how much cpu qpi/vtt voltage are you using?
my 7970 would hit 85c sometimes and still run fine
Whats the PSU?
Corsair HX 750
Not really been keeping a close eye on those to be honest. Not really sure what to use for the best - SpeedFan shows me around 40C right now, not sure how to best check at the point of things going wrong.
No idea where to find any power control slider in CCC, as for voltages? Never toyed with them at all.
