Hey!
I can't seem to figure out why my PC is crashing. No black/blue screen just a freeze and restart. I was away for sometime and started using my PC and noticed these random crashes.
It was in need of maintenance so I took it apart, cleaned it and put it all back together and it seems the frequency of these crashes have picked up
(clearly I am not the best at this). Still no particular pattern, crashes usually when I just have a couple of browser tabs open and Netflix but runs just fine when gaming for a while (which is weird).
No overclock that should make it crash either on the CPU (Auto in BIOS) or the GPU (only fan profile). RAM set to 3600 (it is rated for that), motherboard upto date for my CPU (Notification on asrock website suggests that an update is not needed for my cpu).
I keep seeing this in the event viewer logs:
Points towards a hardware problem I think? but idk where to begin in terms of steps to take. Can someone help me with this please?
Specs:
Ryzen 1600
Asrock AB350 itx
16 GB RAM, 3600 mhz
1 TB Nvme SSD
650W SFX Corsair PSU.
GTX 1080ti
DAN case A4SFX
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 12-Jun-22 11:56:42 AM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: AM
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2022-06-12T09:56:42.0858770Z" />
<EventRecordID>223552</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>AM</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
Specs:
Ryzen 1600
Asrock AB350 itx
16 GB RAM, 3600 mhz
1 TB Nvme SSD
GTX 1080ti
DAN case A4SFX
