The other day my computer was under quite a bit of load and it just completely turned off and wouldn't turn back on until I flicked the power on and off at the PSU. Now there is no signal to the monitor and all the harddrives spin up but they don't click away so windows isn't loading. I have swapped a graphics card with one that definately works, I have also tested RAM, PSU and CPU in another computer and they work fine. I have stripped the pc completely bare and rebuilt it and it still won't fire up. So I think the mobo is dead, agree?
Spec if it matters:
XP1700 @ 230 fsb (2415mhz) (2volts)
Abit NF7-S volt modded
TwinMOS BH-5 @ 230fsb (3volts)
And been running like that perfectly for 3 years to the month so if its died I'm not bothered as I've got my moneys worth!
So if I get another motherboard I think its probably best if I go the S939 route. I can get a 3000+ venice off my mate for £50 so what cheap mobo is best to go with this? Do any good ones have onboard VGA as I don't play games any more and my current gfx is an AGP card? Will I need a new hefty PSU for the A64? Mine is a 340W antec/cheiftec.
Sorry for the noobish post, been out the loop for a while!
Cheers
Spec if it matters:
Cheers
