Pc double boots -
22 Dec 2002
Minehead
Hey,
Looking for some advice as my pc when turned on at the wall will fire up (fans spin) then cut out for a few seconds, before starting again. It does this every single time and I have tried another psu thinking that was the issue.
Someone suggested a possible motherboard fault, would that seem logical?
Gigabyte board? Using latest BIOS? It's common due to dual BIOS chips but newer BIOS should fix it,if not gigabyte board could be cold boot issue
Do you have both the 24pn and 4/8pin power connections installed? If so, try removing and refiting.
Have you tried using the system with one stick of RAM at a time.. Try this for each stick. Then use memtest86+ to verify the RAM afterwards.
Check also the for BIOS updates.. I've had a couple of Gigabyte boards where this has been the case.
Otherwise it sounds like short.
When i had my asus p5q deluxe i asked about this on the official asus forums, i was told that it was the bios checking the strap settings prior to booting. That board would also double boot once you restarted, after making and saving changes in the ai overclocking section of the bios.
My Asus board and my friends Gigabyte board does this, normally after moving (discharging capacitors) or a long time being off (more then 5 hours).
My Asus P8Z68-V pro does the same. If i leave the power supply on its ok but if i turn it off at the mains the fans start & stop twice then boots normally
Blimey - Thanks for all the replies guys!
Its a gigabyte P55a-ud7 motherboard with 2 ati cards in crossfire. Only reason I went for this board was the NF200 chip (not that 16x16 makes any real difference - but it was on offer!).
Memtest is ok, have tried with single strip, dual strip and the four I have in there now. No real difference :confused:
i had a problem like this with my current system last night (msi mobo tho)
i solved it just by loading the default settings for the bios then applying my overclock again that worked for me at least
my asus p8p67 does this every single time it dosent matter what i do with the mains plug or how long its off...
Not quite as often on mine due to changing the monitor? I've not tried the set initial gpu boot to pci-e or something like that.
My previous P55A-UD6 didn't do this. Just the UD7. Which is the reason I'm thinking motherboard has some issue somewhere?
its probably a bios issue,it does get fixed eventualy,i remember my x58 ud5 doing it when it first came out,few bios's later it was fixed, i was told it boots up checks bios then reboots and applies settings then into windows
If it's a new board I would contact the vendor where you bought it from. Check also their terms for flashing the BIOS (if you can)as this may invalidate any warranty.
There are plenty of revisions looking down the list:
http://www.gigabyte.com/products/product-page.aspx?pid=3324#bios
The F5 was the one that caught me out because although I was using branded and supported memory the PC I was building kept restarting.. I managed to flash it using QFlash :)
Page 72 of the manual:
http://download.gigabyte.eu/FileList/Manual/mb_manual_ga-p55a-ud7_e.pdf
Strange all this bouble boot, I thought it was only Asus boards with this problem and mine has reset at least twice. That's why I got an Asrock but just couldn't be bothered to change it over as the Asus board is fine at the moment. Just piece of mind, if the Asus breaks then got Asrock to fall back on.
Thanks mate, I will have a look once I'm on my pc and not the mobile :)
OT Have actually been somewhere someone on here lives! Chelmsford that is!
I've emailed gigabyte to see what they say, as for retailer I will... try ;)
Q.F.T. I had same board with same problem.
On the deluxe this only ever happened if power was switched off at the wall. On that board it was a built in test feature at start up. May be different on newer boards.
