- 29 Sep 2013
After around two years of trying to get my PC to work, i would like to fix it once and for all and would like some advice before wasting my money all over again if that's possible.
The first problem i encountered was some faulty ram, which caused endless problems with games. Easily enough fixed.
Next i got an upgrade from an amd athlon x4 to the AMD phenom x6 1100t, during lots of games i think i heard what was coil whine and the PC still did not seem to work right, i thought maybe the sound was connected so it took it to a professional PC shop, they tested it with prime95 and the whole thing shutdown and would not start, they thought it was a problem with an individual part so they replaced each one in turn, no luck. They ordered a new motherboard, still nothing. They ordered one more and this one for some reason worked. They wanted it out of their hands as soon as they could. So now i have it back and it performs terribly. On most games it stutters horribly skyrim is unplayable, sleeping dogs crashes after 5 minutes and the PC should be able to play all of these games so i don't whats wrong. I have now replaced almost every part in the PC apart from the GPU so thats where im looking now. I'm looking at the Sapphire 11197-12-40G HD7970 3GB Vapor-X Graphics Card. I figured perhaps AMD prodcts may work better tograther.
Time of this report: 10/1/2013, 12:07:13
Machine name: MATT-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130801-1533)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: AMD Phenom(tm) II X6 1100T Processor (6 CPUs), ~3.3GHz
Memory: 4096MB RAM
Available OS Memory: 4096MB RAM
Page File: 4140MB used, 4048MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Card name: NVIDIA GeForce GTX 560 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 560 Ti
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1200&SUBSYS_080110B0&REV_A1
Display Memory: 2770 MB
Dedicated Memory: 978 MB
Shared Memory: 1791 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz
If i get this fixed i would like to be able to run crysis 3 on the highest settings, so i was wondering if its possible to overclock the current cpu i have and the new graphics card i get. Thank you for any help it is greatly appreciated.
Memory: 4096MB RAM
