Caporegime
- 9 Nov 2009
- Planet Earth
i7 940 (22 +1) * 133 = 3059MHz
i7 870 (22 + 2) * 133 = 3192MHz
Turbo boost does run when all four cores are active. Indeed it provides precisely the boost I've ascribed to it when all four cores are active; it would have been irrelevant for me to say the 870 runs at 3.6ghz when only one core is active.
I've read the intel whitepaper on turbo boost and then spent a fair few hours looking into how it works. You've failed to grasp even the basics of its operation.
You also fail to grasp the fact that the socket 1156 setup is faster out of the box,has more RAM and lower power consumption too.
Further I'm capable of independent thought beyond this benchmark. For example, that an architect is going to be bright enough to achieve the trivial 4ghz (with all four cores active) overclock on either chip, making stock speed comparisons redundant.
I know plenty of people who do high speed biological imaging. They have got better things to do then mucking around overclocking computers as it not only takes up their time stability testing but also means more potential issues in the long run. None of these systems or the ones used for processing the large data sets are overclocked.
http://blogs.technet.com/photos/gray_knowlton/images/2998979/original.aspx no hotlinking
Anyway the OP can make their mind up about what socket they want to go with.
