PC for converting/burning dvds/cds + downloading
25 Sep 2009
Can someone please help and spec me a pc specifically for downloading/converting/burning dvds/cds etc..
Im not interested in looks but good performance in these areas would be great..
price range: cheaper the better.
thanks in advance
thanks for the reply, the budgit can be up to £1000 it will be a hard working machine I dont know if its possible to have multi drives burning at the same time, but that would be great,,, so yeh 1k tops..
1k for just dvd writing? This would do tbh:
Product Name Qty Price Line Total
Intel Pentium Dual-Core E5300 "LGA775 Core 2" 2.60GHz (800FSB) - Retail £49.98
(£43.46) £49.98
(£43.46)
Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz Dual Channel (KHX6400D2LLK2/4G) £45.99
(£39.99) £45.99
(£39.99)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £41.99
(£36.51) £41.99
(£36.51)
NZXT BETA Classic Series Case - Black (No PSU) £39.99
(£34.77) £39.99
(£34.77)
PC Power & Cooling Silencer 420W Power Supply £39.99
(£34.77) £39.99
(£34.77)
Asus P5QPL-AM Intel G41 (Socket 775) PCI-Express DDR2 Motherboard £36.98
(£32.16) £36.98
(£32.16)
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM £18.99
(£16.51) £37.98
(£33.02)
Coolermaster Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) £13.98
(£12.16) £13.98
(£12.16)
Sub Total : £266.84
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 15% VAT : £41.79
Total : £320.38
Or a system based on the Athlon II 240 using integrated graphics if you think you would use them. Would have gone with the Atom but any case that supports dual dvd drives kind of negates the size thing...
hmm I was thinking more like 4tb+ (harddrives) more dvd rewriters if multi burning is possible regardless 2 min.
Will be multi tasking so performance must good..
See Id do this myself but havent got a clue how much I can fit in a case or what components go together..
If it was me I would be looking more towards a Phenom II quad, True cpu cooler and WD Blacks or Greens if its just for storage.
You can get Duplicators if you look around, Most Websites that specialise in selling DVD/CD-R's will have them. See if they fit your needs.
