Very kindsadly I'm in London so little bit far away from you in the West Mids!
I am scratching my head as to what else it could be, can't help but think I'm missing something obvious![]()
He's not, I am.![]()
If it is indeed my 1070, I'm in a tricky position as good luck getting a replacement at the moment...
Again though that could indicate PSU, or something else, don't assume!
Have you found anyone to help you yet? I'm annoyed that I am so far away, as I could have had it done for you by now.![]()
Hmm how can I rule it in or out? A mate has kindly offered to lend me a spare GTX460 over the next couple of days. He's willing to help me disassemble and reassemble too - though he seems to think it worth trying another card first.
What do you think?![]()
No harm in trying another card, but given the age of the system and by the sounds of it never had any proper maintenance carried out, then I'd seriously consider the rebuild, with a nice fresh OS on a new drive. You could do that bit first if you prefer, just grab a cheap 240gb SATA SSD, and unplug the cables from your current one, pop that one in, install the 20H2 Window 10 and put up to date drivers on it, and nothing else other than your game that keep crashing.
Brilliant, I will do, at this point I think I have relatively little to loseanything I should be mindful of before picking up a new SSD, are they pretty universal compatibility wise or do I need to pick up a specific one? I've got Gigabyte Z170-Gaming K3 Intel Z170 (Socket 1151) motherboard.
In terms of the windows key, I assume that I can easily find a cheap one online? And then pop it onto a memory stick and install it from there? Drivers wise - what are the essentials, GPU, sound, anything? I've not done a clean install of windows before.
Got there just before me
By way of an update... I unplugged the GPU last night and switched to the painfully slow integrated graphics. Booted up Rome 2 and boy that was a shock, had to lower all the settings and resolution and it ended up looking like a Playstation 2 gameI left it running on the campaign map overnight and low and behold, no crash or freeze this morning. It was running for about ten hours. I think we've found our dodgy part!
Something like a Crucial BX500/MX500 will do should be about ~£25 for 240GB, but yes anything (brand) you've heard of should be fine these days, its only for testing with after all.
No need to get a Windows key as you put it, just get yourself a USB flash drive 8GB+, and on your machine download the Windows Media Creation Tool, and make an installation USB drive, it is very easy to do/follow. Drivers, just grab the latest Nvidia Gfx one, and again drop it on that new USB install drive, once Windows 10 has finished installing, and before you connect it to the internet (tell it you have no connection during setup and unplug the Ethernet if that is what you use), install the NVidia Gfx driver. Once you've done that and restarted the PC, you can connect to the internet and do the Windows updates, may need a few restarts as it will pick up all of the drivers you need. As I said make sure you've disconnected all of your other drives completely prior to starting the install, and during your testing. Windows doesn't need to be activated for it to work correctly at all, and you don't need a license key to install it.
did you check event viewer and see if there are any errors listed for CPU mem or drives etc
