PC Gaming and 5.1 Audio
29 Aug 2003
Wales
Hi all,
So is it just me or are hardware vendors and games developers not bothering with 5.1 audio any more. There's hardly any 5.1 packages to purchase and the games are lacking 5.1 audio. Is there a solution here i'm missing as I thought the PC gaming community would be all over 5.1 sound.
I can't remember the last game I played that didn't support 5.1.
Can you point out what games you having trouble with? If you mean dolby or DTS from a game to sound system then you need dolby live or DTS connect.
I may have been slightly hasty with the games support actually. Far Cry 3 didn't show having 5.1 in the options, but when i went into the game i could hear all the sounds...
But, There definitely does seem to be a lack of 5.1 systems about. I've also noticed they recommend you put the effects speaker to the side of you, whereas I always thought they go to your rear. They seem to sound better when they are behind me.
You correct on placing the rear speakers behind you. When you have side speakers that's 7.1
Exactly what i thought, but the Logitech manual shows them to the side, and in Windows 7 Sound setting the picture also shows them to the side. IF you want to select 'rear' speakers you have to select the 7.1 option.
Maybe there correct? Haa either way it shouldn't matter with me the rear does play as normal. But I do use DTS connect for sound system. This encodes 2.0 from game to 5.1 and sends to receiver were it's decoded and played back.
I also have roccat Kave 5.1 and I don't think they a game I played so far that hasn't had 5.1.
In 5.1 the surround speakers are to the side and slightly behind the listening position. It depends on the type of surround speaker what angle to face it.
In 7.1 the rear surrounds are more at the rear.
select 7.1 and disable the side speakers:D ive had to do that a few times
but it should give you 5.1 side and 5.1 rear options
