PC Help!?
9 Jan 2011
Hey guys,
first post so i thought i'd ask something...
I'm currently saving up for a semi decent PC the problem i face is funding there fore i wanted what sort of spec's i should go for with £350- £400 without including the Graphics Card nor the PSU..
all advice will help!!
Thanks
Irksomebroom
Probably worth mentioning first that the graphics card is the most important part of a PC for gaming, and it is very heavily dependant on the PSU, so both of these need to be done properly.
Aside from that, what parts do you need? Do you already have a case, monitor, optical drive, OS, keyboard, mouse?
I won't be using it for gaming, manily things like Photoshop!... i've got a LCD tv which ill hook it up to using HDMI, i need all the internals eg motherboard, processor, ram, cooling, case......
